ping? dyno or not??
ping? dyno or not??
so my bike is starting to ping a little. but only if i lug it. i don't lug it a lot but you know sometimes you hit the wrong gear or something. so should i get it dynod or just try to never lug it? i think its only happening now because its really hot summer this year. i always use premium gas. im just worried its ping more than i know. because its hard to hear over my exhaust. thanks.
Don't lug it. Mine was pinging when hot at 3k RPM. After my dyno, no more pinging and i gained 8% hp and torque. No regrets. Make all the changes before paying for a dyno!!
Lugging the motor will cause pinging reason: when lugging - the oil pressure is at its lowest and the disbursement is not adequate for the motor. It really has nothing to do with tuning but it is bad for the motor due to oil distribution.
If the other guy had pinging and a dyno solved the problem then it wasn't related to Lugging.
Dyno testing is used to check or increase performance, it can be bad for your engine, I have seen several engines come apart during the process, usually caused a by some weak point in the engine but none the less, it's not the way I want to find weak point in my bike.
If your riding a heavy street bike and not acting the fool on the street, the only other reason to consider a dyno is fuel mileage.
Lugging and pinging can be corrected without a dyno run.
You'll notice I did not tell you to have your bike dyno'd or not.
efi + hot weather = best likelihood of pinging
solutions include best available fuel, enrich fuel mixture, supplemental engine cooling
dyne will correct the second item but is only one part of the solution
also, inherent design of v twin engine does not like lugging, not only oil pressure, think of the stresses put on internal moving parts, all solvable by increasing rpm range
