Dumba** mistake
Did the same thing a couple of weeks ago. Had rented a Limited and was cruising at 75 on the freeway when I accidently hit the kill switch. I didn't touch the clutch or brake or change lanes. Just hit the switch back on and kept riding. I imagine if I had pulled the clutch in I would had to hit the starter button after moving the kill switch back (or just release the clutch), but with the clutch engaged it immediately restarted and kept going with hardly missing a beat.
I've wondered if hitting the "off" switch would do anything, while the engine was on and in gear. I hoped it'd be unable to be turned off by accident. Now I know.
I guess I'll be taking a quick glance before I hit the signal. Or glueing some kind of bump on it, so my thumb knows where it's at, like the #5 on a key pad.
First few weeks after selling my Vulcan and getting Switchback, hit turn signal and as I move to right on freeway, realize left signal blinking.
That's what the kill switch is for, to kill the bike in case of emergency. In you cage, if you turn off the switch, it's going to die whether you're in gear doing a 100 mph or in park in your garage.
Kill switches make sense... putting them in the same approximate location regardless of manufacturer does too.
After an accident, with the bike on its side, running and in gear with the wheel spinning - may be the best reason for killing the engine.
First responders need to know where it is and use it quickly.
