Heated Gear size questions
Plan on purchasing heated liner for cold weather riding. Do the liners run true to size, orto wards the larger size. I'm going to order from cozywinters.com I think their line of warmgear is made by Gerbings, which also are the suppliers for the HD gear. I normally wear a large shirt or jacket, but the size chart for the heatgear looks like a large would be rather big for me. I plan on wearingjust a T-shirt, the heated liner, and my leather jacket that also has a liner.
RE: Heated Gear size questions
Find a dealer with the heated gear in stock and try it on under your riding jacket. You want it to fit snugly, but not be restrictive, and, of course, it should fit under your jacket.
If you're talking about a full sleeve liner, you'll also want to wear alongsleeve tshirt. Heated gear can get real uncomfortable (hot) against your bare skin.
Gerbings web site asks for your measurements so they can provide the proper fit. http://www.gerbing.com/heat/jl.html
While you visiting the web site check out the warranty.
FBL
FBL
MichiganMikey
Gear and Other Items For Sale
07-07-2014 01:36 PM
