2013 ultra
Pro's - New frame, 103 engine, larger rear tire, slightly more carrying capacity in bags and TP. Brembo brakes, etc,etc.
Cons- You start over adding mods
I went from a 2007 RKC to a 2010 Ultra Limited and have no regrets.
Ultra's went through a whole list of changes in 09. New frame, reroute the pipes, and more. I had an 07 and it was one of the hot ones, my 09 is great and other than the cats in the pipe (con) the 13 will be a different, better IMO, ride than your 07.
Pros - better handling, still hot but less than your 07, more luggage space
Cons - still hot
Cons - still hot
I'm on my second Ultra, which is an 07. Three weeks ago the factory demo team came through here and I rode the 2013 Ultra Classic Limited. If you can swing it, this is the ultimate tourer. It handles excellent, plenty of power, the brakes are awesome, and it comes with a lot of accessories the regular Ultra doesn't have. If I weren't so old and feeble, I'd buy one to replace my current ride. Go for it.!
IMHO, the biggest "con" is the catalytic converter.
Too much heat in order to get a "clean" fuel burn and the engine and the rider takes the brunt of the heat.
THere are ways to rectify the problem and I'd recommend doing it to a new bike a.s.a.p.!
Went from a 12 Heritage Softail Classic, to a 13 Ultra Limited. NIGHT & DAY.
The FLHTK is SO much better all around! Almost....
The draw back that I'd complain about is the heat from the cat on a hot day, it's almost unbearable to sit in traffic with that much heat generated from the bike.
