J & S Jack Review (you gotta get 1 of these)
#111
#112
Received 4,361 Likes
Engine cases and triple trees.
Everything else has been taken off the bike at one time or another.
Thinking about doing a stroker this winter so I guess I will just be down to trees by spring.
FWIW I never had to put a strap on the bike at any time.
#113
Here's the link to my review:
https://www.hdforums.com/forum/gener...ly-review.html
#115
There's little doubt they are the best.
However not everyone whats to or can spend $450+ for a jack.
What the Redline dolly does that the J&S jack doesn't is it opens up the underside of the bike so that you have no obstructions when the bike is elevated..
Now is that a big deal? Perhaps not to some.
The Redline dolly does IMO do what the J&S jack does the best and that is provide stability when the bike is elevated.
It just does it for a hell of a lot cheaper.
So along with an $80 Harbor Freight jack plus the $100 Redline dolly a person can have the stability of the J&S jack and have clear access to the underside of the bike.
Again I'm not against J&S jacks I just think for the money the Redline dolly provides a better option for moving around the bike and doing so with maximum stability not to mention doing it for $300 less (including the cost of a cheap jack).
#116
First off I'm not against owning a J&S jack.
#117
The J&S jack might be too wide.
I believe the width is where the stability is.
According to the Redline spec:
"Adjustable width from 18.25" to 25.25" wide"
I think that's outside to outside.
I measured the pads at 2.25" so at 25.25 outside to outside, the maximum inside spread width would be 20.75.
For those with the J&S jack already I'm not sure it would worth the $100 to add the Redline dolly to the garage.
However for those with a cheaper jack or those looking for a new setup the Redline dolly is a cheaper option than the J&S jack but IMO provides equal stability.
#120
J&S jack usage
Just received my J&S jack. In particualr the Trike Jack (My wife has a Freewheeler) and the adapter for my Street Glide and Fatboy.
Solid built well made item but....
The handle for lowering the bike is real tight against the bottle jack. i have big hands and it's hard to get a hold of the device especially when you don't want it dropping like a brick!
Anyone else having this problem and if so do you have a solution for this issue.
I will rig something up to get a better grip just wondering if anyone else has conquered this problem already!
Talldog
09-20-2010 10:49 PM
