Touring frame flex question
Would you folks know how to check a touring bike frame or frame number to find out if it has the flexing frame issue. Im considering buying an 2000 ultra classic and didn't want to run in to that issue.
Thank you!
Stew
Thank you!
Stew
I don't think there is a correlation between serial numbers and flex. My understanding is it happens on some, not on others. The pre 09 bikes are apparently more susceptible, but the 09 and later (new frame) are not exempt. I think the best you can do is make sure the bike has been maintained and hopefully take it out for a ride to see if it squirms in sweepers. Obviously I wouldn't hammer on it. Just go easy and see if it feels twitchy.
Yeah.....not the frame itself. But, I think we all know what it is he is referring to.
This mysteriously seems to affect the people who do not check their tire pressures or bother setting up the forks to suit their weight more than others, a good alternative to bothering with these basics is to stick a lump of metal on the frame and complain about vibes instead.
I have the "old" frame and have not experienced this ever. The new frame was designed for the trikes. The rear section is bolted on. This allows for the same frame to be used for both, just bolt on the rear that is needed.
That 2000 is a sweet bike. Buy it without worrying about "flex".
