Kuryakyn Pro-R Hypercharger Issue??
I just installed a Kuryakyn Pro-R Hyerharger on my 2004 Dyna Wide Glide. It has an 88 motor and stock carb. I bought the bike used and it has after market exhaust on it. The installation of the Hypercharger went well but when i started the bike, the idle is low and when it is at normal operating temperature it does not run unless i have the throttle slightly turned or the choke partially on.
Has anyone ran into this issue before? Do i just need to adjust my idle?
Thanks!
Thanks!
1st, adjust the idle on the bike to get the RPM's up a little bit. Then you need to adjust the Air/Fuel mixture to get a little more fuel into your motor. Too much air......not enough gas. That's why you have to have the "choke" out or have a little throttle working to keep the bike running. Here is a link that show you how:
http://www.harley-performance.com/ha...arburetor.html
The vacuum lines are hooked up correctly. The carb was jetting when the exhaust was installed. I will try adjusting the fuel and idle. Thanks for your help! I will let you know if i have any additinal issues.
Your problem is not that the Hypercharger is giving you too much air at idle.
You said the vacuum lines are right -- and I'm sure you're correct. But I had that Hypercharger on a Yammy once... and when the vacuum line got a crack in it where it hooks up, the bike didn't want to idle.
Good luck... hope you figure it out soon.
