ABS on 08 Road King?
I have a 08 Road King Classic - 105th anniversary edition. When ordering braided cables at the dealer I was asked if it has ABS. I didn't have the bike with me and the parts guy couldn't tell from the VIN. Anyone know how I can determine this? Appreciate anyone's response.
I don't have ABS but I think if you look at the left side of the front wheel if it is abs you will have a black spacer and you should have a wire coming out of the abs sensor.Non abs should have a shiny spacer.It should also have a flashing light come on when you start up that will go out when you start rolling.
Also there's a black plastic retaining clip for the wire thats mounted on the clutch side brake caliper, if you look close it says ABS on it. The big givaway on an FLHRC (Classic) is the wire, although models with fender lights like the FLHR also have a wire that runs down in front to power the light.
If you still can't figure it out pull the brake side side cover off and see if there's a brake line junction block there- if there is it's ABS.
the reason your dealer needs to know if it has ABS or not is because on NON abs brakes, your brake line runs from your right hand grip master cylinder straight to the tee block under the forks then to each caliper.
on ABS brakes, your brake line from the right hand grip master cylinder runs back to your ABS control module, then another line goes forward to the tee block under the forks, then to each caliper.
suggestion: on ABS brakes, when changing brake lines, pull the 40 amp breaker from the fuse box BEFORE you start and DO NOT put it back in until you FINISH bleeding the brakes. failure to do so will set off the ABS fault code and it will take a trip to the dealership to re-set the code.
did I mention experience is the best teacher of all
ABS Brakes
I'm looking at changing brake lines after my handlebar conversion. I would have missed the 40 amp breaker trick for sure.
gus4440
09-28-2014 11:32 PM
rakanghoth
12-02-2008 02:27 AM
