Throttle grip
If it's sliding off the inner plastic sleeve just glue it on. Gorilla glue is awesome, but messy. use it sparingly.
Had the throttle slip off a ISO grip. I used 3M weather adhesive to glue it back on.
http://www.amazon.com/3M-08008-Black.../dp/B00063X38M
Just be careful on the amount used so it doesn't end up where you do not want it.
I'm running PM one piece aluminum grips now.
take grip off, wash it in plain gasoline, slip on , let dry a hour .and presto, wont slip , will come off later using a small screwdriver inside , and wd-40.
