Using old speedo as display clock
Old 03-06-2013, 01:31 PM
Wide Glide 25's Avatar
Wide Glide 25
Wide Glide 25 is offline
Default Using old speedo as display clock
I remember seeing someone else ask this question in another thread but didn't find any answers. I recently replaced my stock speedo with the HD 4 in combo digital speedo/analog tach. Is there an easy way to return power to the old speedo just to display it as a clock?
Old 03-07-2013, 02:43 AM
Watch Guy's Avatar
Watch Guy
Watch Guy is offline
Default Easiest way to do this is
get yourself a quartz movement from a clock supply shop. They're usually only 3 to $5.(same type of movement that wall clocks have.) You may need to drill out the center hole on the speedo dial a bit to accommodate the clock stem. Then get yourself some hands from the same place as the movement and just glue it onto the backside of the dial. It won't be lit for nightime but should look pretty cool.
Old 03-07-2013, 08:43 AM
Pumba11's Avatar
Pumba11
Pumba11 is offline
You can just buy them.
Old 03-07-2013, 08:45 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,258 Likes on 4,784 Posts
If you have a service manual with the schematics you might try taking it and the speedo to someone that is up on 12 volt electrical and have them take a look at it. Might be able to rig something up to allow you to power it off of 120.
Old 03-07-2013, 08:59 AM
jimsflh's Avatar
jimsflh
jimsflh is offline
Need a long *** extension cord to use 120v
(LOL, I know it was a typo IA, just messing with ya)
Old 03-07-2013, 09:10 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
Prolly wasn't a typo...
Like myself, he was probably thinking the OP wanted a wall clock. But after reading the other responses, he may want to use it on the bike?
And many of the craft shops have the quartz movements also, just a little more expensive there.
Old 03-07-2013, 11:24 AM
IronAss's Avatar
IronAss
IronAss is offline
I was under the impression he wants to put it on a wall or bookshelf or desk.
Old 03-08-2013, 05:04 AM
Watch Guy's Avatar
Watch Guy
Default Either or it's an easy fix
I make and repair clocks and those quartz movements for wall clocks are very small and run off an AA battery. All he's have to do is replace the battery once in a while. You can get the sweep (smooth movement) second hands or the (tick tick) for each second on the seconds hand. The hr and minute hands come in many different sizes.
Old 03-08-2013, 05:12 AM
Watch Guy's Avatar
Watch Guy
Default I'd be glad to help you with this
clocks and watches are kinda my hobbie. Send me a pic of the front and rear of the speedo and its case and I may be able to send you what you need. Need the inside diameter of the case and how deep the back is and the exact diameter of the dial. I don't think I can help with the 12V power source though, just the AA battery idea. Pretty hard to find analogue clocks for cars that don't require a lot of repair.
Old 03-08-2013, 05:17 AM
IronAss's Avatar
IronAss
IronAss is offline
When I was laid up after surgery a few years ago, I would buy take off air cleaner covers and make clocks out of them. I would get the movements at JoAnns fabrics (craft store). I sold them on ebay and made my beer money.
I don't have a newer bike with the speedo that has a hundred functions but I'm assuming the newer ones have a clock of some type built into them and he is wanting to use that one. At least that's the impression I get from reading his original post.
Maybe he'll come back on here and clarify it.
Quick Reply: Using old speedo as display clock
