Condensation
RE: Condensation
My toys have been stored in a cold garage for 40 yrs.other than bare cast iron or steel,and a good spring cleaning nothing is bothered internally.At first I was a little **** about that.There will never be anything to worry about unless your toy sits beside a window that the sun can hit it.Now that you DO NOT want to do!!!!
RE: Condensation
Well, the bike is in a non heated garage, but I have a propane heater I light everycouple of daysso it is just warm enought to work out for an hour or so. No Randy, no drier venting there
No windows near, either Dog, just about a bike length in from the doors. ( which have insulation stuffed all around the edges)
So just leave it be til the winter is done & then reclean it ??
Thanks guys
Thanks guys
RE: Condensation
this may be beating the topic to death but oh well, the only way I can see that you are getting moisture is because of a temp change in the garage. Warmer air will hold more moisture and as the air cools it hits a dew point where it can no longer support the amount of moisture in it, the moisture then collects onto the best conductors available.
RE: Condensation
But if I leave it be, the bike will be ok ( given a thorough cleaning , weather permitting)? I am thinking, from what you all have said, it is the on-again-off-again heating of the shop that is the problem..... so that would mean no working out til lawn-mowing time..hmmm....
Budweiser, anyone???
RE: Condensation
Katie....If you have all your chrome polished you will probably be ok....I however neglected to use chrome polish on my rear pulley and that "on- again off-again" condensation caused surface rust on that pulley....It cleaned up ok but it did cause the rust....Try the fan....seriously...Scott
RE: Condensation
Thank you Scott,, but duh-me moment.. will the fan simply just blow all the cold air around??What good is that?? Bike was 'put to bed' squeaky clean & polished..... Is it not the heater sporadically heating & then allowing the air to cool, causing my question?
