Does the weight of an engines rods effect horsepower output?
Old 02-21-2013, 05:02 PM
FBRR's Avatar
FBRR
FBRR is offline
Originally Posted by soft 02
Yes it effects the available power and where it comes in but does it increase power?
"A rotating mass does not really consume energy. The mass just stores energy and eventually returns energy to the system or converts it to some other form of energy. "
If YOU think pistons and rods are rotating MASS you need to go back to engine design 101!!!!!!!!!
  #32
Old 02-21-2013, 05:29 PM
fat_tony's Avatar
fat_tony
fat_tony is offline
They move in relation to the rotation of the crank shaft and contribute to inertial generated dynamic forces that act on the engine and ultimately produce vibration, so yes they are considered part of the reciprocating mass.
  #33
Old 02-21-2013, 08:05 PM
teflon's Avatar
teflon
teflon is offline
WOW i figured the guy just wanted the cliff notes. We could go crazy and discuss how cam profile, valve timing, length of rod, counter weight mass/diameter/ and where the weight is located on said flywheel but were gonna really go into some serious math/engineering that i dont think most here will get. (thats no disrespect) Then we could bring in what your gonna use it for, drag racing, road racing, high speed runs....it all changes what you do to said engine. way to much to get into without typing for a week!!! lol like whats been said short answer is YES!!!
  #34
Old 02-21-2013, 08:26 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
  #35
Old 02-21-2013, 08:35 PM
soft 02's Avatar
soft 02
soft 02 is offline
"Weight is the measure of the earth's gravitational pull on an object. Mass is a measure of the amount of matter in an object. Put a vehicle on the moon and its weight changes; its mass does not. Inertia is a measure of an object's resistance to a change in direction or acceleration; mass affects inertia, weight does not, though the distinction matters little when drag racing on this planet. However, the more mass, the more inertia--and the more inertia, the more the resistance to acceleration."
--David Freiburger
  #36
Old 02-21-2013, 08:43 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,987 Likes on 17,898 Posts
Softy buddy we'll have to plan a a hook up weekend when our schedules allow and summer gets into swing and have this conversation over some fine malted beverages , this one is gonna go sideways fast in here .
  #37
Old 02-21-2013, 08:50 PM
soft 02's Avatar
soft 02
soft 02 is offline
Already has. Still not convinced.
  #38
Old 02-21-2013, 08:52 PM
oppirs's Avatar
oppirs
oppirs is offline
I want to be that fly(Camera) on the wall. For that exchange.
Best of buds.....forget it. Nothing will happen.
Still would like to know how a few shaving of Kg, or Onces. From what part of the rod will aid performance?
  #39
Old 02-21-2013, 09:05 PM
FBRR's Avatar
FBRR
FBRR is offline
The rod big ends are rotating mass, pistons and the top end of the rods are are NOT ROTATIONAL! There is a physical limit to how fast you can stop and start a PISTON and ROD top end and it relates to weight and piston speed.
here is a good explaination of the difference in ROTATIONAL MASS, and what is and what isn't "rotational".
P.S. you changed form ROTATIONAL to Reciprocating, those are two different things!!!
http://www.eatonbalancing.com/blog/2...ancing-part-1/
  #40
Old 02-21-2013, 09:47 PM
TwiZted Biker
Plenty will happen , laughs , good conversation , female harassment and general male oriented nonsense ......... seriously .
While the tech speak aspects of what getting tossed around in here are true for the most part the reality of it is in a v twin long stroke engine like the beasts we love have lightening the rods ( what little can be done ) has no real street usable gain . Your going that far into one it's a motor thats gonna see the drag strip or salt flats . You'll get the gains at the outer rim of the rpm ranges Joe Blow average owner fears to go .
Quick Reply: Does the weight of an engines rods effect horsepower output?
