Damn Ethanol .. ( I hope )
Living in Georgia, I usually don't go more than a week, even in winter, without getting at least a 25 - 50 mile ride in.
Since before Christmas I've only been able to ride about 100 miles, so I'm on the same tank of gas since then.
My bike, an '02 Heritage FI, started running rough after about 25 miles. The second time it did this was when I arrived back home. I pulled into the garage with the clutch in, it sputtered, ran rough, then died. It sounded so bad my wife came outside to see what was wrong with it. It would crank, but only run, rough at that, with the trottle held open. Left to idle it would go dead.
Worried that maybe the coil was going bad, or worse yet, the alternator, I stopped by my mechanic's shop a few days later. When I told him what it was doing he asked when was the last time I put gas in the tank. When I told him before Christmas he said my problem was the ethanol in the gas.
He had some additive called Star Tron, 7 bucks for a 8 oz bottle. He said it was probably cheaper at a parts store or walmart. It wasn't, 10 bucks there. I bought a bottle from him rather than looking for it somewhere else.
Along with another gallon of gas, put some in then let it run 5 minutes to run it through the fuel system.
A few days later I was able to go on about a 40 mile ride and it ran fine. The next day, a 30 mile ride, everything ran good again.
I'm not 100% sure if ethanol was my problem yet although it looks like it was.
Has anyone else had a problem like this that was caused by ethanol?
MAL
MAL
I always run ethanol free gas in all my vehicles, but I doubt ethanol would cause the gas to go bad in 4 or 5 weeks time...I've let vehicles sit for months with ethanol in the tank & never a problem
Mal74, it matter how long gas in your tank has sat or whether your 4,6, or 8 cylinder has run ethanol without issue since jump street.
When gas is blended with alcohol (creating mix or mixed ethanol) the mere fact that alcohol is hydrophilic (meaning it attracts moisture) water can accumulate in your gas tank resulting in reciprocating combustion imbalance point blank.
It's a long shot but mine did something similar. It wasn't the gas but rather a pinhole had developed in the pressurized fuel lines in the gas tank. (IT's fuel injected.) It ran rough as hell and was so bad it was embarrassing. It would run sort of ok with a full tank but after 50 or so miles it would run crappy again. It's a cheap fix if that's the problem.
JW
JW
I'd really be surprised if your issue is ethanol related. Sounds more like water from condensation....especially where you are with alternating warm and cold days. Since water is more dense than gasoline water would be on the bottom of the tank. Did you have a full tank when you went for the ride that ended with a poorly running motor? If not, maybe your fuel pump was just getting to the bad part. Heet, Seafoam or that expensive stuff you used could very well have done the job. Fill up with fresh gas and go for a longer putt and see what happens.
I can easily believe it was the gas.
For the last two years the fuel we've been getting locally.
I know for a fact if you leave the same gas in anything with a carburetor for 2 months without running it the carb will be gummed up to hell.
Fuel injected doesn't suffer as bad but one will run like crap if you leave it sitting for a few months learned this the hard way leaving my extra truck sitting a few months.
SeaFoam is your friend.
Thats why I always fill the gas tank on anything I store. You need an air space for condensation to form. I also put in some fuel satbilizer. Ive never had a fuel problem doing those two things.
