valve noise
Old 11-13-2012, 07:03 AM
gonpce's Avatar
gonpce
gonpce is offline
Default valve noise
I just purchased by first harley 09 fatbob and have notice when riding there is some valve noise coming from the from the front cylinder. Is this normal? (my last bike 04 honda always had some noise)Just trying to see if I need to have the bike looked at. I'm new to harleys and don't know what to expect, but I really love the 09
Old 11-13-2012, 07:10 AM
omaho5's Avatar
omaho5
omaho5 is offline
Some valve sound is OK.
Old 11-13-2012, 07:18 AM
BassCatcher's Avatar
BassCatcher
BassCatcher is offline
They all bang and clatter. Mine sounds like a sewing machine sometimes. It comes with the Territory.
Old 11-13-2012, 07:19 AM
lo-rider's Avatar
lo-rider
lo-rider is offline
Sounds like you're lugging your motor. Use a lower gear.
Old 11-13-2012, 07:23 AM
cardboard's Avatar
cardboard
cardboard is offline
Don't know why but the newer bikes makes more valve noise
My 11 does it
Old 11-13-2012, 02:34 PM
Mikey 1450's Avatar
Mikey 1450
Mikey 1450 is offline
Its hard to say with out actually hearing the engine. Is it always noisey of only when hot? My advise would be to let someone listen that knows Harleys. Depending on the mileage, maintenance and history, they have hydraulic lifters , BUT, they can sometimes be adjusted slightly and it can make a difference.
Old 11-13-2012, 03:36 PM
nevada72's Avatar
nevada72
nevada72 is offline
Received 26,140 Likes on 12,206 Posts
That.
Thought I had normal noise and it turned out to be too much crank runout.
Old 11-14-2012, 08:04 AM
wraplock's Avatar
wraplock
wraplock is offline
You don't tell us anything about the motor or any work that was done before your purchase so it can be hard to give you good advice. But.....
If the PO installed cams they may have installed adjustable push rods. These have a habit of coming loose after a while and need attention. I would remove the upper retaining clip on the offending valve's push rod cover. Push the bottom of the tube up to expose the bottom portion of the push rod and see if there are two 7/16th" nuts. One is for locking the adjustment and the other is used to adjust the length of the push rod.
I have noticed in my twin cam motor that the valves make more noise with the use of synthetic motor oil.
Old 11-14-2012, 09:19 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
HoggyMtnBreakdown is offline
Can't hear anything in the valve train over all that noise the damn balancer chain makes on mine...
Old 11-14-2012, 12:17 PM
gonpce's Avatar
gonpce
gonpce is offline
The motor is stock 96 with vance and hines short pipes and 2000 miles
Quick Reply: valve noise
