V&H QUIET BAFFLES QUESTION
RE: V&H QUIET BAFFLES QUESTION
I think someone asked about this before and the answer was no... the sound will only be changed by about 5db or so... I don't think that will change the restriction THAT much...
It changed the way the bike ran, but Jamie said I didn't need to change the tune.
It gave me a ton more bottom end.
***EDIT
OK, maybe not a ton but I could definately feel it and it wasn't minor.
***EDIT
ORIGINAL: Rhubarb
ORIGINAL: Custom07RKC
How bad were they to install??? You have to take off the heat shields to install them right??? I was thinking about installing them just haven't got around to it yet.
ORIGINAL: Rhubarb
So I spent about 45 minutes trying to get the shields off. I finally gave up and took the pipes off, then the shields. Took like 5 min.
This is the route I would go if doing it again.
Twist the baffles in and they will go fine. I used a nail to line up the screw hole.
Dale M Ludwig
Exhaust System Topics
02-26-2012 06:19 PM
