stupid question alert. clutch and shifting
Old 10-22-2012, 07:52 PM
TurkeyRun's Avatar
TurkeyRun
TurkeyRun is offline
Originally Posted by ElectraGlideSteve
Sounds like your clutch might need adjusting.
I always leave my bike in first gear when I shut it down, so it doesn't roll.
I always shift to neutral before starting, just seems to me there's less stress on everything when starting it in neutral.
Old 10-22-2012, 07:56 PM
Sauceman's Avatar
Sauceman
Sauceman is offline
Originally Posted by soft 02
Cold thick fluid between the plates causes drag. Perfectly normal.
Agreed, parasitic drag.
cheers
Old 10-22-2012, 08:38 PM
redsled's Avatar
redsled
redsled is offline
Another thing I heard a long while back which I now do as a habit whether I'm starting from neutral or in gear, is give the clutch two or three squeezes before hitting the starter. I was told this squeezes some of the oil out from between the plates, which, when cold, is what produces the drag you are experiencing. Wet clutches are all pretty much the same, so I expect it works this way on other bikes, too. And I always start with clutch pulled in, even in neutral.
Old 10-22-2012, 10:17 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
My easy way, bike in neutral, engage clutch just out of habit, let clutch out, start bike, put helmet and gloves on, upright bike, stand up, engage clutch, put in gear, ride on.
Old 10-22-2012, 10:31 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,988 Likes on 4,179 Posts
My clutch is in good shape and adjusted perfectly (I even know my clutch plates are flat and not warped since I just went thru primary at 40K-- plate were within .001 of new) The primary oil level is correct to level, not amount, and correct harley spec. If I leave it in gear and just pull in clutch, you can here it pull down (slow starter) and fill it tug bike. Thats just the nature of the beast. Until they are spinning, the drive disks stick to the driven disks.
Old 10-22-2012, 10:46 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
Well it looks like your questions are answered other than the warm up one.
All oil is too thick at room temp. So yes letting the bike warm up is a good idea. In the summer I let my bike run for a couple minutes before I take off. And be easy on the gas for the first 5 minutes. 5 minutes riding and my oil cooler is hot as hell so I'm guessing it's up to operating temp,then go ahead and twist er
Old 10-22-2012, 11:35 PM
arcticharleyman's Avatar
arcticharleyman
arcticharleyman is offline
Can I also ask a stupid question? Ok. Thanks.
Is there no neutral light indicator on the Wide Glide?
Old 10-23-2012, 06:45 AM
hdgzr's Avatar
hdgzr
hdgzr is offline
Received 2,784 Likes on 802 Posts
Originally Posted by Mercyfulfate
Thanks for the reply.where are you at here in OK? im actually in Norman.
I'm in Broken Arrow...
NCBANDIT
03-11-2019 04:52 PM
BuzzCap7
17
05-06-2017 09:21 AM
ridemyglide
2014-2023 Touring Models
17
09-21-2015 07:28 AM
travalab
06-28-2013 01:01 PM
Springermoneypit
03-27-2012 01:10 PM
Quick Reply: stupid question alert. clutch and shifting
