Slow primary leak
Old 10-21-2012 | 03:20 PM
AlanStansbery's Avatar
AlanStansbery
If you haven't replaced the drain plug o-ring recently, I'd do that, then torque the plug to *spec.*
Alan
Old 10-21-2012 | 06:50 PM
badwhine's Avatar
badwhine
Originally Posted by Pagman
Oh no! I have an oil leak on my harley. Who would've seen THAT coming? Ugh. Here is my issue...
I have an 02 dyna fxdx with a slow oil leak coming from the primary right by the drain bolt. The drain bolt is fine. I think the primary needs a new gasket, but not too sure. The leak actually started when I thought one of the primary cover bolts (the one closest to the drain bolt) was the actual drain bolt. Boy did I make a mistake and I think I disturbed the primary's gasket. Anyway, the leak is not a drip-drip leak, but more like it's a spot on the ground in the morning kinda leak. When I don't ride for a few days, the spot looks more saturated. As we know, the primary requires a quart of oil, but how much oil can the primary run on before too little is in effect? I'm thinking of adding more than a quart for the meantime (to prevent refilling often), but how much extra oil can I add before the extra is too much?
Shift shaft seal!
Old 10-21-2012 | 08:24 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
My 02 FXD has had two shift shaft seals replaced in 46k miles. The second involved replacing the shifting pawl, $$$. Use a small mirror and flashlight look at the shift shaft where it goes in to the tranny.
TravisD27
04-29-2018 08:30 PM
WideGlideFever
06-09-2015 06:00 PM
tmanbuckhunter
EVO
04-25-2014 03:49 AM
Spanners39
EVO
04-03-2014 07:40 AM
Histicku77
Exhaust System Topics
08-01-2013 12:08 PM
