Lifetime Oil Filter
Old 01-26-2007, 09:25 PM
HD7585's Avatar
HD7585
HD7585 is offline
Default RE: Lifetime Oil Filter
BikeWorks magazine Just tested this filter. Not only dose it cool the oil, but the oil flow is so superior that when the same HD was put on the dyno first with a HD filter then with this filter....The engine gained 4to5 HP With this filter on. 200 bucks for a 5HP gain plus a oil cooler aint all that bad.
Old 01-26-2007, 09:55 PM
Ram's Avatar
Ram
Ram is offline
It would be good to have two of them. One to keep in a cleaning solution or ultra-sonic cleaner, the other on the bike. That way you can have a quicker oil change.
Aircraft jet engines have metal filters similar, they do a great job of filtering.
All are a bit expensive. But, you get what you pay for, and when you want the best you pay the most. At least you'll be satisfied!
Old 01-26-2007, 10:03 PM
Dick Johnson's Avatar
Dick Johnson
Dick Johnson is offline
WHY would you want to clean out an oil filter?
Old 01-26-2007, 10:13 PM
Dick Johnson
I rode for twenty years before we even had oil filters on bikes........a screen used to be good enough
Old 01-26-2007, 10:25 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Would you risk the warranty for $600.
Old 01-26-2007, 10:27 PM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: Dick Johnson
It is a good indication as to engine health to see what kind of 'stuff' is getting trapped in the filter element.
These are very good products to have, but not for everyone. If you want to know why old iron had just a screen, its because the engine tollerances were not very tight and anything could almost pass through the engine with harming it.
Modern 90's on... engines have such tight tollerances the better filter you have the better the oil is kept clean. Oil is the life blood of your modern engine, it cleans the engine, it cools, and lube's the friction surfaces.
All in all, the better you take care of your oil, the better your taking care of your engine.
Sure you can do just about as well, with paper filters, and the Amsoil filters with the nano technology sound almost as good as these cleanable ones.
Its all up to each individual.
I'm looking at them, not going out and buying anything right now, just looking mind you.
But, I do like what I see.
Old 01-26-2007, 10:31 PM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: 1FLTRI4ME
I have only the stock warranty. After that its all on me anyway.
And if you did change out to one of these units you have the "Magnuson-Moss Warranty Act, 15 U.S.C. SS 2301-1312 (1982), and general principles of the Federal Trade Commission Act, a manufacturer may not require the use of any brand of product (or any other article) unless the manufacturer provides the item free of charge under the terms of the warranty."
(That ditty about the Mangnuson-Moss and FTC act I've quoted directly from Pure Power)
Old 01-26-2007, 10:34 PM
Dick Johnson
Don't get me wrong......oil filters are a great thing,but I cant justify $200 for a filter when you toss away a $10 filter. Maybe there is a horsepower gain, but if you believe every vendors claim of increased horsepower.....we would all be driving around on 250 HP machines.
Dick
Old 01-26-2007, 10:36 PM
1flhtk4me's Avatar
1flhtk4me
I forgot about that.
Old 01-26-2007, 10:40 PM
HD7585's Avatar
HD7585
HD7585 is offline
The HP gain was provided by a independent test by Bike Works maginzine.......They used their Dyno for the test....The vender wasn't involved
Dick
Quick Reply: Lifetime Oil Filter
