Notices
Road Home on Busted Cam Chain Tensioner
Old 10-28-2012, 09:04 AM
SamStone's Avatar
SamStone
SamStone is offline
When my friends tensions went out half way to Sturgis, I had them check mine while they were fixing his. Mine had very little wear at 30,000 miles. $193 and worth every penny, so far from home. It cost him $1200.
  #42
Old 10-28-2012, 08:00 PM
traveler's Avatar
traveler
traveler is offline
The "cure" for 99-05 Twin Cams:
http://www.harley-davidson.com/gma/g...8&default=none
  #43
Old 10-28-2012, 08:15 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Originally Posted by traveler
Doesn't that leave the inner chain a Morris flat ling style though?
  #44
Old 10-28-2012, 08:37 PM
traveler's Avatar
traveler
traveler is offline
not sure on that.
this is supposed to put all the chain tension on the one shoe in the front. Being an SE part, you know the R&D has been done, and it works as stated.
The smart route is to do this, with Torrington Cam bearings at the same time. The ball bearings suck....needle bearings are the way to go IMHO. That's what I did on my 2011 Streetglide 103 when I swapped to SE 255 cams.
~Joe
  #45
Old 10-28-2012, 09:07 PM
Sauceman's Avatar
Sauceman
Sauceman is offline
Nope, still a patch. Gear drives is the cure.
cheers
  #46
Old 10-30-2012, 07:58 PM
traveler's Avatar
traveler
traveler is offline
agreed, until you develop too much crank runout.
Bumpandrun
60
11-13-2018 07:09 PM
adsinclair
01-09-2011 12:23 PM
boston138
08-14-2010 10:43 AM
dbleagle
06-02-2009 08:54 AM
vernh59
06-10-2006 11:31 PM
Quick Reply: Road Home on Busted Cam Chain Tensioner
