Alarm tip on the speedometer
Old 09-14-2012 | 07:20 AM
binetto's Avatar
binetto
6th Gear
Default Alarm tip on the speedometer
Hi,on the speedometer is written tip and the starter motor does not turn,What mean tip?
Greetings from Italy,Fabiano.
Old 09-14-2012 | 07:26 AM
piasspj's Avatar
piasspj
The bike was laid over on its side. Simply turn off the ignition and kill switch then turn them back on.
Old 09-14-2012 | 07:43 AM
stro1965's Avatar
stro1965
It usually means you dropped your bike.
Old 09-14-2012 | 11:00 AM
binetto's Avatar
binetto
6th Gear
Has always been straight,I tried to turn it on after 6 months and found written tip.
Turn on all, fuel pump, lights, turn signals, but does not turn the starter motor.
Old 09-14-2012 | 11:14 AM
binetto's Avatar
binetto
6th Gear
No fall,now explain:
On display written the miles,active button run and appears tip together with a spy designed engine(then disappears and remains tip),active run and does not turn the starter motor.
Old 09-14-2012 | 11:17 AM
MetalSpike's Avatar
MetalSpike
Turn on the kill switch then turn the ignition switch off and on 5 times. That should do it.
Old 09-14-2012 | 11:26 AM
piasspj's Avatar
piasspj
Sounds like it may be a problem with the sensor or wiring causing the bike to thinks it is on its side.
Old 09-14-2012 | 12:57 PM
2kids3pets's Avatar
2kids3pets
How about pulling the main fuse or disconnecting the battery for a few minutes to clear the error
Old 09-15-2012 | 02:45 AM
binetto's Avatar
binetto
6th Gear
Hi,where is the sensor?
Old 09-15-2012 | 02:50 AM
binetto's Avatar
binetto
6th Gear
Hi,already tried, but reappears alarm tip.
Quick Reply: Alarm tip on the speedometer
