Battery Light Flickers on after bike starts...?
Old 09-21-2012, 06:20 PM
cowboy-bc's Avatar
cowboy-bc
cowboy-bc is offline
Ya check the voltage prior to starting and needs to be over 12 VDC then check it while running and it should be around 2 volts higher. The other thing is I had a voltage reg that quit charging when it was hot so you might want to check it when it's hot too.
Old 09-21-2012, 07:12 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Battery Light
Mine has been doing that for years without any problems whatsoever. I had a six year old battery until this last spring when I replaced it because of an up coming trip. I put a new Dekra (it's what Harley uses) and it still comes on for about 1 sec, right after start up.
BTW It started doing that after I started using a battery tender.
Old 09-26-2012, 02:53 PM
Junior_co's Avatar
Junior_co
Junior_co is offline
Update 9/26/12:
Today while running around, I started her up and the engine light came on as well as the battery light. Also on the speed-o display, it popped up with something like "V?????" That disappeared and both the other lights went back off as well.
Put a meter on the battery when I got home. Voltage was ~12.3vdc with the bike off. It dropped to 9.25 VDC when starting and up to 13.5-14.25 while running....
I remember reading about the "v??????" message somewhere on here, so I'll look around for that to see what it might mean in relation to all this...
So, if ya have any more suggestions, please let me know...
Jr
Old 09-27-2012, 09:26 AM
cowboy-bc's Avatar
cowboy-bc
Having dicked around with a charging system the dealer couldn't figure out those numbers are good.
AFDynaRider
09-12-2018 01:11 PM
5wheels
08-06-2018 06:33 AM
spankdog
03-17-2016 08:50 PM
BOSOXFan
08-28-2015 01:01 PM
darrinfish
08-22-2010 07:27 AM
Quick Reply: Battery Light Flickers on after bike starts...?
