Wide rear tire and passenger?
Old 09-10-2012, 12:43 AM
Andy Titus's Avatar
Andy Titus
Andy Titus is offline
4th Gear
Default Wide rear tire and passenger?
Sorry if this had been covered, but haven't had any luck finding anything.
I'm considering getting a Fat boy and would like to add a wide tire kit but haven't hardly seen any bikes with a wide tire and a passenger seat.
Is a wide back tire and a passenger generally a bad idea? I would like to add a 250 and a passenger seat.
Thanks for any help!
Old 09-10-2012, 07:41 PM
Benway's Avatar
Benway
Benway is offline
As long as the fender is still fully supported, I don't see why not. May not look right though...
Old 09-10-2012, 08:16 PM
Midgard's Avatar
Midgard
Midgard is offline
suction cup pillion pad
Old 09-11-2012, 06:41 PM
Andy Titus's Avatar
Andy Titus
4th Gear
Thanks!
I'm leaning toward not widening it, considering the stock rear is already 200.
Old 09-11-2012, 08:46 PM
dgdamore's Avatar
dgdamore
dgdamore is offline
Originally Posted by Andy Titus
Thanks!
I'm thinking that is the way to go. Personally the fat tire fad was silly to begin with. Form IMO, should always follow function, and I think over 200 you're not gaining anything performance wise.
Also, I can see a fat tire if it has a real small fender that shows off the rim and tire, but to just cover it up with a wide fender seems silly to me.
Old 09-11-2012, 08:50 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
I don't see anything wrong with it. Unless the passenger's butt isn't wider.
Old 09-11-2012, 09:45 PM
jmorganroadglide's Avatar
jmorganroadglide
jmorganroadglide is offline
Big Kahuna HDF Member
Received 2,305 Likes on 1,344 Posts
Don't completely understand the semantics of it, but when buying a new wheel, make sure to get one that any tire machine will work on. It is nice to have any indy change a tire. Also, when you get up to the size tire you are referring to, remember that it won't be a stock item if you use the bike for touring. If you ruin a tire in a remote area, you may be there for a while.
Old 09-12-2012, 01:43 PM
dsbfxdwg's Avatar
dsbfxdwg
dsbfxdwg is offline
Wide tire
Wide passenger
VENNUM
12-06-2009 08:07 PM
drstephennix
Wheels/Tires
14
10-31-2009 12:44 PM
Fightn_Tiger
04-01-2008 03:56 PM
Doug45601
11-13-2007 03:36 AM
bodyman0
11-18-2006 10:56 PM
Quick Reply: Wide rear tire and passenger?
