Exhaust paste?
09-08-2012, 11:02 PM
Exhaust paste?
does anyone know of a sealer to use on slip on mufflers?
What have you done to ensure a airtight seal?
Thanks
09-09-2012, 03:01 AM
A good quality muffler should fit snugly to a Harley headpipe, with no "paste" required. Harley muffler clamps do the job.
09-09-2012, 05:23 AM
Quote:
Originally Posted by
SIREx
does anyone know of a sealer to use on slip on mufflers? What have you done to ensure a airtight seal?
Thanks
Stay away from the cement type sealers. That stuff will "weld" itself to the pipes and cause a real mess when removing/reinstalling the next time.
FWIW, I've found that using a pipe expander to make sure each end of the pipe and muffler is round instead of oval makes for a good seal.
Hope that helps!
09-09-2012, 06:00 AM
Not to seal but anti-seize is recommended for ease in taking off the mufflers.
09-09-2012, 06:13 AM
As I remember, the factory used clear RTV silicone on the pipe/muffler joints on my bike.
09-09-2012, 08:22 AM
Permatex Ultra Copper RTV silicone. It is designed for this kind of application. I use it on car and truck collectors all the time too. I stays pliable enough to keep a seal for years, and comes apart fairly easily too.
09-09-2012, 11:15 AM
sgt. slaughter
+1
that's the best stuff to use
09-09-2012, 12:28 PM
Try the Ultra gray not the copper , it blends in better for the little bit you can't get to wipe off . Been using it on shovels & pans to hold pipes on the heads for years .
09-09-2012, 02:51 PM
I used RTV Hi-Temp, it's black. Indy used the copper anti-seize and it leaked by and burnt my muffler.
09-09-2012, 03:07 PM
