Bike tries to move forward when starting.
When I start my bike, it will try to move forward a little. I have the clutch in and when I ride the clutch seems to work fine. I have tried adjusting the clutch via the clutch cable, but doesnt seem to do it. What else can i try?
Thanks in advance.
Thanks in advance.
Same
I don't start mine in gear often but the few times I have for whatever reason it does the same must be just the way it is. Don't believe they were designed to be started in gear, seems easy enough to just put it in neutral.
Clutch plates are just touching oil level by design and when used the oil film will get between the plates which will allow them to slip when the lever is pulled. After sitting the oil will drip out of the clutch ASM and dry plates will tend to stick together when you are starting up. Check your primary oil level to specification and start in neutral
