Bike tries to move forward when starting.
Old 09-06-2012, 04:45 PM
Andjh123's Avatar
Andjh123
Andjh123 is offline
it's usually worth a few chuckles when someone on an older and/or converted bike has it in gear and forgets to pull in the clutch before hitting the starter...(assuming no major damage or injuries of course)
Old 09-06-2012, 04:52 PM
Mark_H's Avatar
Mark_H
Mark_H is offline
yep...done that dumb dumb move a few times over the years. Never dropped one doing it but it never fails to make you look like a fool.
Old 09-06-2012, 09:09 PM
nevil's Avatar
nevil
nevil is offline
Received 1,034 Likes on 773 Posts
Originally Posted by Raider Dana
I have tried adjusting the clutch via the clutch cable, but doesnt seem to do it. Thanks in advance.
Common misconception. The cable adjuster is for adjusting the cable, something you do after adjusting the clutch itself.
Old 09-06-2012, 09:13 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
It should be called a slack adjuster!
Old 09-06-2012, 09:22 PM
Andjh123's Avatar
Andjh123
Andjh123 is offline
lol...and I as well. The most recent time I bumped it up hard against the curb in front of me with a bunch of coworkers watching.
Old 09-06-2012, 10:03 PM
vizcarmb's Avatar
vizcarmb
vizcarmb is offline
Seriously dude every bike does that when you start it in gear
Old 09-06-2012, 10:46 PM
Andjh123's Avatar
Andjh123
Andjh123 is offline
Edit: nevermind
Old 09-07-2012, 04:04 AM
roadking2000's Avatar
roadking2000
roadking2000 is offline
I shouldn't be surprised so many start their bike in gear since my owners manual clearly says "Always shift the bike into neutral before starting to prevent possible movement". Lots of really good info in that owners manual. Some guys should try reading it. Your starter just might last a little longer if you did.
Old 09-07-2012, 06:40 AM
milesvdustin's Avatar
milesvdustin
milesvdustin is offline
I didn't think you could start in gear with the clutch in. My 2008 fxdc won't start unless in neutral.... Do I have a problem with this thing now?
Old 09-07-2012, 06:56 AM
soft 02's Avatar
soft 02
soft 02 is offline
When my neutral safety switch went out in my lever I could only start in neutral. FWIW.
Quick Reply: Bike tries to move forward when starting.
