Which cables?
Received 24,128 Likes
Which cables?
The next thing I want to do to the bike is change out the stock black cables. I've seen the regular stainless steel cables and the Diamondback cables H-D makes, and I do like the Diamondbacks. But what about other brands? Anyone recommend anything other than H-D cables?
Philip
Philip
RE: Which cables?
Also the Magnum Sterling Chromite II are in the same class as the Diamondbacks. I have seen them personally and they look good. They are cheaper too.
RE: Which cables?
I don't know anything about them other than what has been said on this forum...
You want to have ones that have a clear vinyl cover on them, correct? And I seem to recall that they need to be replaced on a regular basis? Could be wrong.
RE: Which cables?
RE: Which cables?
I just purchased the Diamondbacks and I'm very impressed
with the quality of these cables. I think Barnetts makes cables
as well but not 100% sure on that.
RE: Which cables?
ORIGINAL: went_postal
RE: Which cables?
ORIGINAL: wlbowers
That's why you buy the ones with the clear covering. With out this outer covering, dirt can get between the braid and the inner tube and grind through the inner tubing. You can't see this happening.
Thanks!
