Tank emblem removal
Old 08-21-2012, 05:17 PM
89Speedy's Avatar
89Speedy
89Speedy is offline
Default Tank emblem removal
Hey guys, any idea how easy it is to remove a chromed tank emblem without screwing up the paint finish? Any particular technique?
Old 08-21-2012, 05:18 PM
purpledeuce's Avatar
purpledeuce
purpledeuce is offline
Dental floss or fishing line, clean the residue with goof off and then wax
Old 08-21-2012, 05:27 PM
liljoejoe54's Avatar
liljoejoe54
liljoejoe54 is offline
^^^^ This. Its easy to do if you heat up the emblem first with a heat gun or hair dryer. If you dont have either of those then you can leave your bike in the sun for a bit then give it a go.
Old 08-21-2012, 05:30 PM
Midgard's Avatar
Midgard
Midgard is offline
Old 08-21-2012, 05:31 PM
EP50's Avatar
EP50
EP50 is offline
Use the floss..I did ..impressed the hell out of my dentisit
Old 08-21-2012, 05:40 PM
jaysledge's Avatar
jaysledge
jaysledge is offline
Dremel tool and painters tape, go very slow. jk
Dental floss after leaving the bike in the sun. If you have a denim paint job, it will leave a shadow.
Old 08-21-2012, 06:04 PM
WetSider's Avatar
WetSider
WetSider is offline
Agreed on the floss or fishing line. I'd use "Goo Gone" vs. "Goof Off" to be safe. Even the Goof Off website says to use their heavy duty product vs. their professional product on painted surfaces, so that tells me caution needs to be exercised on your tank's paint.
Old 08-21-2012, 06:16 PM
davidsdad's Avatar
davidsdad
davidsdad is offline
Heated with a hair dryer then peel off slowly while keeping the hair dryer on the emblem.
Old 08-21-2012, 06:52 PM
HOGBOY57's Avatar
HOGBOY57
HOGBOY57 is offline
use fishing line get heavy duty. i took street glide emblems off my bike and came off easy.and just peeled the remaining tape off. i put sreamin eagle emblems like the look.
Old 08-21-2012, 09:15 PM
Rick-e's Avatar
Rick-e
Rick-e is offline
I'd use lighter fluid over goof off or goo be gone. I've even used it on a lacquer finished guitar to remove adhesive from a pick guard.
Quick Reply: Tank emblem removal
