blown headlight fuse
08-03-2012, 08:30 PM
I keep blowing headlight fuse
08-03-2012, 08:31 PM
keep blowing headlight fuse on 2002 ultra
08-03-2012, 08:53 PM
What amp fuse are you using? Whatever you're using bump it up by 5. See if that helps
08-03-2012, 09:22 PM
When fuses blow it means that it is shorting to ground. Fuses are the week link. That holds true to all electrical wiring. Very rare if not that
08-03-2012, 09:36 PM
Check your hi-low beam switch for a short.
08-04-2012, 05:47 AM
Quote:
Originally Posted by
nytryder
Also check the bulb socket...mine melted on my '00 Fatboy
08-04-2012, 06:11 AM
Had the same thing happen on my 2008 ultra. Blew the headlight fuse everytime I rode. I changed the headlight itself, and problem has not returned in over 2 years.
If you don't find a definate short...change the bulb. They short out occasionally too.
jamess71
05-18-2023 01:27 PM
sabunimwil@gmail.com
09-08-2021 04:06 PM
FGriffis
09-15-2018 12:47 AM
Davemac122383
10-07-2016 03:57 PM
seandrew
12-16-2013 09:00 PM
