Brake light is stuck on!!
Anyone have any idea as to what might fix this issue?! I am supposed to be at the Iowa Grand Motorcycle Rally and I'm not (for obvious reasons) Neither my hand or pedal brakes are triggering the brake light.
Check the bulb first, then make sure the pull off spring is hooked up to the rear brake light switch. After that disconnect the front brake switch to make sure that isn't the problem. If none of that sorts it out then start chasing wires to see where the cross is.
cheers
cheers
cheers
cheers
Thanks to all for the repsonses! However I am just going to wash my hands of it and run it over to my mechanic. I did try the bulb, no dice. I guess I'll have to waist this sunny weekend in my SUV at the rally!
Do like tombeving said, pull a wire off of one of the switches. I have an 08 fatboy and mine stayed on, pulled one of the wires off the rear switch it went out. Ran it awhile till I got a new one, I use both brakes anyway. New switch was about $21 and took about 10 minutes to change, that included going after my 2nd beer. I didn't even have to bleed the brakes afterwards either.
Finding the problem switch should only take 30 minutes or less. It ain't brain surgery. Changing out the switch can take some time especially if you haven't done it before. About an hour the first time I did one---last one I did took ten or fifteen minutes. Hope I don't get to good at that skill.
