Fork Oil ??
That would be my guess also. IMO though, you are never going to find a definitive answer because manufacturers do not comply to a "standard" (as with motor oils). The closest I've come to an actual answer is this thread, which I started quite some time ago. That said, I think your best bet is to get the opinion of someone you trust that has experience with the different fork oils (i.e., NOT a Harley dealership).
There is no apples to apples with fork oils..
Each brand seems to have their own standard...
the info I've found on MoCo is
E is 5 wt
B is 10 wt
SE is 15 wt
SE heavy (racing) is 20 wt
When I had my Indy change my fork oil last yr, they had 10-15-20. and I don't remember what brand it was..
Seems like they used the 15 or 20, it for sure was heavier than the (E) HD oil.
I noticed it was a little firmer at first.. then after a few rides it seems like I could have even went with a little Heavier...
I've read most go with the SE 15.. but U'll have to decide on that.
E is 5 wt
B is 10 wt
SE is 15 wt
DR. V-TWIN
03-15-2011 07:51 PM
