Any Chain drives left?
Old 01-14-2007, 11:58 AM
pococj's Avatar
pococj
pococj is offline
Received 1,296 Likes on 483 Posts
Default RE: Any Chain drives left?
ORIGINAL: xxxflhrci
ORIGINAL: dsb
You should get up to 20k as long as you keep it adjusted right,and dont pull to many hole shots,biggest problem is people make them to tight and then they wear faster,if it is a swing arm bike make sure you are sitting on the bike when you adjust it should have a bout a half inch of play on the lose side of the chain
I've put 2 Tsubaki 530 HSL-NP chains on my Ironhead. The first one lasted about 10k before it was stretched beyond service. The second one now has 14k on it and is way shot. I'd used them at the recommendation of an indy buddy. I did a little searching this week on them. They are rated for only 650 cc bikes....Go figure an Ironheads torque is harder on a chain than a sportbikes, h.p.......At 110 bucks a pop, I'm done with them. I did some shopping and found a Western Powersport nickel plated chain for 26 bucks. I ordered on this morning and am going to see how well it holds up.
I used to go to a joint called Farm & Fleet and buy bulk chain. The farmer stuff lasted as long as the heavy duty high dollar Tsubaki chains, as long as I kept 'em lubed and adjusted. Used some Kawasaki spray on lube. It worked pretty well, and was cheaper than the HD lube, or the specialty chain lubes, too.
  #52
Old 01-14-2007, 12:11 PM
HD7585's Avatar
HD7585
HD7585 is offline
I've been using a spray on Dry lube...........Yes Dry Lube. Goes on wet..........Then the transfer agent evaporates and leaves a dry but thick film that stays put and causes no fly off mess. you can even touch it with your finger and your finger will be clean.Also no dirt or sand stick to it..........So the chain stays clean.......Great Stuff!.......Got it at a suziki dealer
cbacon1788
05-03-2018 10:17 AM
dukeinhaler
Ironhead
08-27-2014 08:46 PM
85RoadsterXLS
Ironhead
13
08-18-2008 11:37 AM
gatorg
02-18-2008 08:19 PM
Quick Reply: Any Chain drives left?
