Can not get security system to disarm
Old 05-28-2012, 07:43 AM
Hawgin's Avatar
Hawgin
Hawgin is offline
2nd Gear
Default Can not get security system to disarm
I have a 2007 softail custom and ran into an unusual problem yesterday regarding the security system. The bike recognizes the FOB when nearby (lights don't flash) but will not fully disarm the system. I even tried bypassing it with the pin using the turn signals but the system will not enter the mode to do it as instructed. Disconnected the battery and replaced the FOB battery but system still is locked up. Anyone run into this before?
Old 05-28-2012, 07:54 AM
williamfrog's Avatar
williamfrog
williamfrog is offline
Try to disarm with pin, without FOB anywere near bike. System will not go into manual mode with it near bike.
Old 05-28-2012, 07:59 AM
Hawgin's Avatar
Hawgin
Hawgin is offline
2nd Gear
Tried that already too and did not work. Dealer recommended letting it to sit for 20 minutes before trying again to reset and also did not work. Also read switching the ignition switch on and off 10 times would reset it. No luck there either.
Old 05-28-2012, 08:16 AM
streeteagle's Avatar
streeteagle
streeteagle is offline
Do you have any new electronic devices in your house? Any businesses
close by that may have a wireless alarm system newly intalled? Try moving the bike away from your house about 100 feet or so & try it again.
Old 05-28-2012, 08:19 AM
Hawgin's Avatar
Hawgin
Hawgin is offline
2nd Gear
It happened outside a restaurant. Had the bike towed home and still doing it. Also tried using the 2nd FOB. Do you think it could be a low bike battery not having enough juice to get it fully disarm?
Old 05-28-2012, 08:25 AM
streeteagle
If the battery has enough juice to crank your bike I can't imagine
there's not enough power for the alarm system. How old is your battery?
Old 05-28-2012, 08:34 AM
Hawgin's Avatar
Hawgin
Hawgin is offline
2nd Gear
5 Years. Just talked to a Service Manager at a Dealership. They are completely mystified over this. Said the culprit is usually a low battery in the FOB but have never seen this before.
Old 05-28-2012, 08:46 AM
skratch's Avatar
skratch
skratch is offline
Received 4,370 Likes on 2,543 Posts
he actually doesn't know if the battery has enough juice to crank, the security won't let him.
moving it 100 ft away isn't necessary either. if there is something nearby that is interfering with the signal, then using the override code will take care of that. if you cant enter the override code, then something else is wrong.
since the bike is at your house already, and you've already put new batteries in your fobs, then i would definitely take a look at the bike battery. how old is it? put a multimeter on it, throw it on a charger, or if you have access to another, replace it completely and see what happens.
*edit* just read where you said it is five years old. sounds like it's time for retirement. did you tell the dealership how old it is? and they didn't try to sell you a new one?
Old 05-28-2012, 08:57 AM
cbrenthus's Avatar
cbrenthus
cbrenthus is offline
Received 1,643 Likes on 683 Posts
Does your fob have the Prox sensor or button? On my wide glide, I pinched the wires to the security antennae and it couldn't pick up the fob. Once I realized what happened, I'd already set off the alarm. Once the alarm went off, it wouldn't give me enough time to enter the pin. I would wait for it to stop going off, but once I turned the the ignition on to start the procedure, the alarm would go off before I could finish.
streeteagle
I KNOW that, I meant before the problem. I agree, a new battery is
in order in any event, might solve the problem..
Quick Reply: Can not get security system to disarm
