Tire pumps.......
Old 05-27-2012, 08:13 AM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is offline
Received 1,686 Likes on 704 Posts
Ive got scuba tanks left over from the paintball days. Put a 3000 psi co2 regulator on it and it works good for tires.
Old 05-27-2012, 08:16 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I also have a #10 Co2 tank but it's a hassle to get it filled!
Old 05-27-2012, 08:42 AM
Haywired's Avatar
Haywired
Haywired is offline
I have a good compressor in the shop and carry a co2 cartridge tire inflator. Only propblem with the co2 inflator is I can't find genuine HD air cartridges for it...
Old 05-27-2012, 09:08 AM
FlamedFXR's Avatar
FlamedFXR
Here is what I use.
Old 05-27-2012, 09:43 AM
TKDKurt's Avatar
TKDKurt
TKDKurt is offline
I carry the H-D one the plugs into the battery tender pigtail. I has the built in gauge which, over the year since I have had it has proven to be accurate.
Old 05-27-2012, 09:57 AM
SanJuanRon's Avatar
SanJuanRon
SanJuanRon is offline
Me too, having air available at any time is a big plus. You can use it off the pigtail or the 12 volt on the touring bikes. SJ Ron
Old 05-27-2012, 10:18 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
CHOPPIN' CHARLIE is offline
Use a hand held pressure gauge. Even a new one could be off a little. Buy two and still can be off. Always check pressure in shade, always when tire is equal to ambiant temp. Never ride to a place to check or adjust PSI. When ambient temp. drops 10 degrees, tire will loose 1 PSI and never return. If you get a compressor with a tank it might say to drain tank mt because water will condense. Don't want water in tires. I keep all my tires to maximum pressure (cold) tire folks stamp on side of tires. Might consider using nitrogen if you can trust folks deflating and inflating your tires. Use it in my car and truck but not in Heritage. Air and Dyna Beads do bike just fine.
Old 05-27-2012, 12:41 PM
FXDXTSport's Avatar
FXDXTSport
FXDXTSport is offline
Originally Posted by HDmikie
Just curious what kind of tire pumps do you guys use on your bikes? I've been using a cheap bicycle pump but not sure how accurate it is. Thanks!
I guess because I'm not the sharpest knife in the drawer is the reason I don't understand the question. Do you have a bicycle pump with a built in pressure guage? It really doesn't matter what you use to put air in the tires. You can use a hand pump or a monster compressor, you just need a good pressure guage to check the pressure, which you should do quite frequently.
Old 05-27-2012, 12:56 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
I use an 80 gallon, two stage compressor.
Old 05-27-2012, 01:43 PM
im's Avatar
im
im is offline
an inexpensive 12 volt compressor that i removed the outside cover in order to lesson bulk.
http://www.webbikeworld.com/Motorcyc...cles/air-pump/
Quick Reply: Tire pumps.......
