Severe Tendonitis!
Old 05-13-2012, 09:47 PM
Rick-e's Avatar
Rick-e
Rick-e is offline
Originally Posted by streeteagle
No, but if you're not on blood thinners & your stomach is in good shape
try some ibuprofen or naproxen sodium.
Yeah I'm on cumodin for blood clots, I'm calling my Md in the am, to see if I can take acetominophen, or maybe he has another anti inflamitory I can take..frustrating when you cant ride!
Old 05-13-2012, 09:53 PM
dan conner's Avatar
dan conner
dan conner is offline
my doctor will give me a steroid shot when mine gets too bad...can only do that once every few months though. isn't there some kind of easy clutch accessory to lighten the pull or how about a hydraulic clutch?
Old 05-13-2012, 09:56 PM
Rick-e's Avatar
Rick-e
Rick-e is offline
Thanks for all the other replies, even the "cut it off" reply, been using ice and heat and a tennis elbow brace, it's getting better. Also like I said I'm calling the Doc in the am.
Like they say... too old to rock and roll....too young to die!!
Old 05-13-2012, 10:01 PM
Louderisbetter's Avatar
Louderisbetter
Louderisbetter is offline
Go see a chiropractor...some do what's called "stripping", not the good kind...it's where they strip down your arm and try to fix it that way, they will also get you to do some special exercises. After a month if that doesn't work go see an orthopedic doc...get an MRI. They show more than a doc can see from the outside. You could have a ruptured tendon.
Go to a doc and be sure. Cortisone shots hurt like hell but can offer temporary relief
Old 05-13-2012, 10:29 PM
streeteagle's Avatar
streeteagle
streeteagle is offline
Acetaminophen is OK, but DEFINETLY NO ASPIRIN, but you should go by
your doctor's recommendations.
Old 05-13-2012, 11:01 PM
Biker Oma's Avatar
Biker Oma
Biker Oma is offline
I've got it too, much better now, but when I abuse (over use) my right arm. Husband calls it Garden Elbow, because thats how I damaged it. Digging plants out, transplanting them elsewhere, weeding. I wear a brace when I do repetitive moves like sanding or raking. It takes a LONG time to heal, and way too easy to set it off again. Good luck.
Old 05-14-2012, 06:23 AM
oct1949's Avatar
oct1949
oct1949 is offline
they make mods that will help..
http://www.demonscycle.com/Shop/Cont...EasyPullClutch
Old 05-14-2012, 06:38 AM
chamba's Avatar
chamba
chamba is offline
Originally Posted by oct1949
best response yet......... I guess after 26000+ posts it just comes naturally.
Old 05-14-2012, 08:10 AM
kzoo's Avatar
kzoo
kzoo is offline
I had it bad last year. Not so much this year and did not change a thing.
Old 05-14-2012, 09:02 AM
Rick-e's Avatar
Rick-e
Rick-e is offline
On my list for today:
Acetominophen
Ice packs
lube clutch cable (all the cables while I'm at it)
Order Easy Pull kit
Thanks for the replies!
Quick Reply: Severe Tendonitis!
