Broken Handlebar Riser Bolt: Watch Your Bushings!
Regarding a torque wrench (of which I have three): I think I'm missing something here. This was caused by [a ridiculous amount of] play in my bushings and stress over time. Or are you saying that the left bolt should've held the handlebars in place after the right bolt snapped if it were torqued correctly?
If that's the case, I'd say that it was and finally loosened after it had had enough. Who knows how long the right bolt had been severed. I'd never removed those bolts before, btw.
^^ Really?? The play in the bushing has EVERYTHING to do with why the bolt snaps! If there was no play, say welded...it wouldn't snap. Physics.
Adding apes is like putting a huge prybar on that junction of riser/bars/triple....any slack or play in that area is going to cause stress on the bolt. Hence, you ALWAYS replace the bushings when adding bars with aftermarket poly bushings
Doesn't matter if your apes are 3 feet tall, the force at the riser bolt is still the same because it doesn't bear on a fixed (rigid) point, it floats in the bushing.
