twin cam 88 running terible. please help!!!
Old 06-13-2012 | 10:53 AM
hd-kw's Avatar
hd-kw
4 day ride thru Arkansas planned this weekend ! Thanks again guys
  #62
Old 07-27-2012 | 02:13 PM
rottnutz's Avatar
rottnutz
Hey Hd_Kw, I read through your thread here. I was just curious, how are things are going with your ride since your fix? I'm having a similar problem and will be digging into it.
Thanks.
  #63
Old 07-27-2012 | 03:00 PM
oct1949's Avatar
oct1949
Originally Posted by hd-kw
*** Update ***
Fixed! Finally ! Fixed!
Hole in gas line in tank and broke / cracked fuel regulator housing. Resulting in 42 psi fuel . Now has 59 psi fuel. Thanks again for all the help and info.
Had the same thing on my 07 last summer,
It just started missing out after about 90 miles on a tank fill up. After second time I knew what it was because all the times I've read about it in here. Thank God I was near enough to gas stations that she didn't die on me.
After the second time I filled up around every 50 miles till fixed.
I was over 500 miles from home and it took 3 dealer stops to find one that had all the parts to fix her..
Charles in W, Vir. took me right in and I was on the road 2 hrs later with all new parts inside the tank..
Any way U now have some new parts along with new fuel lines and filter.
  #64
Old 11-02-2013 | 12:07 AM
Snake1973's Avatar
Snake1973
4th Gear
Default fat boy running problems
also like tlb say to change your injectors out . you also metioned you changed your exhaust multiple times i would get a super tuner and get it dynoed
  #65
Old 11-02-2013 | 06:26 AM
oct1949's Avatar
oct1949
Just thinking, when mine had the pin hole in the gas line and was running bad a couple yrs ago she had several diff Codes when checked by the wrench at Charles in WV.
After fixing He cleared them out and rode my bike for a while to make sure nothing else showed up.
In my reading seems the pin holes can be caused by Ethanol in the gas, some say Using Sta-Bil can do it, (makes the gas line Soft) and others say the line is rubbing in the tank in some others.
Any way just glad Ur up and running.
Cory Epperson
07-25-2018 09:09 AM
Smile_N_Ride
09-26-2015 11:37 AM
WiscoKid
Engine Mechanical Topics
05-06-2014 10:22 PM
mdstitt
07-08-2013 04:23 PM
abjones
07-18-2006 08:46 PM
Quick Reply: twin cam 88 running terible. please help!!!
