Dyno results - 05 Fatboy Anniversary
Old 08-07-2005 | 02:47 PM
HD4ME's Avatar
HD4ME
Default RE: Dyno results - 05 Fatboy Anniversary
Thanks for the info. Looks like new cams are on the wish list now. I assume a new dyno would be in order if new cams were installed, correct? Would the PCIII need a new map?
Any ideas on a good cam for low end torque and HP?
Old 08-07-2005 | 02:52 PM
pilot1996's Avatar
pilot1996
New dyno run or PCIII at a minimum. For what you are describing, the 203s will probably best suit you, though 204s are an option...
A buddy here has 203s on his otherwise stock motor (he does have a stage 1 and a Mikuni carb), and his bike has a little extra kick in the low to mid range...
Hope this helps,
Mac
Old 08-07-2005 | 03:51 PM
HDF Tech's Avatar
HDF Tech
The 204's come in and last a bit higher in the rpm range over the 203's
Old 08-07-2005 | 07:26 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Your numbers are right on. Stock 1450 hp is about 67. Considering your motor is basically stock with nice pipes and the PCIII you are doing really good. If you want big numbers your talking high compression pistons, cams and ported and polished heads. I'm running 80 hp with my 95.
Terry
TennesseeGene
08-28-2012 03:31 PM
Thundercloud
04-17-2009 06:54 AM
DaveHD333
08-23-2007 09:32 PM
blz2503
11-12-2006 09:54 PM
harleynt
06-10-2006 12:51 PM
Quick Reply: Dyno results - 05 Fatboy Anniversary
