last year of a well built, non smog Harley
Old 04-25-2012 | 01:57 PM
qtrracer's Avatar
qtrracer
Originally Posted by DK Custom
"last year of a well built, non smog harley"
Pressed together crankshafts that can twist are not what I would consider well built.
The pre-2003 Twin Cams were much higher quality than the 2003-later. But you might need to go back to the evo to get a well built motor. 1999
On Sportsters, the motor is well built to this day, but 2006 was the last year that was mostly unaffected by smog crap, but fortunately it is still not nearly as bad as the TC bikes
The cranks are all pressed together. The con rods don't have caps on them to be installed on a solid crankshaft. I have never heard of a solid crank harley.
Old 04-25-2012 | 03:40 PM
hoethree's Avatar
hoethree
I will put my 1999 FXR2 Evo on that list.....80 cubes and carb...simple, elegant, works!
Old 04-25-2012 | 06:59 PM
JB's Avatar
JB
Hell my first new HD a 93 Springer was lean burn, they told me not to panic when I pulled and checked the plugs the first time the mech told me he'd take care of it when I brought it in for the 500mi because they knew I was going to be changing out the pipes and intake.
Old 04-25-2012 | 07:05 PM
txfxstrider's Avatar
txfxstrider
1939?
Old 04-25-2012 | 07:17 PM
RFG7680's Avatar
RFG7680
Originally Posted by txfxstrider
1939?
Ya I was thinking 1969. Seriously..
Old 04-25-2012 | 07:54 PM
piasspj's Avatar
piasspj
Can't ignore the electric bikes 2018-2021. The Hydrogen fueled bikes 2021-2035.
I won't count the nuclear models that will come out in 2036. (They won't be environmentally friendly, Zombies don't care).
Old 04-25-2012 | 08:55 PM
dgdamore's Avatar
dgdamore
2002 might be a good year for EFI bikes. Got the Delphi system that year. 2001 EFI was atrocious.
I wonder what the last year was they were built entirely from parts made in the USA?
Old 04-25-2012 | 10:30 PM
piasspj's Avatar
piasspj
I'd be surprised if any Harley built since 1903 had all parts made in the USA.
Old 04-25-2012 | 11:48 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Prior to the twinkies, the big twin cranks were bolted together...not one piece, but not pressed together and susceptible to twisting out of true.
2000 and later Sportys are also pressed together cranks, but there has not been a big problem seen with them that is being seen with the Twin Cams.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 04-25-2012 | 11:59 PM
Stiggy's Avatar
Stiggy
Originally Posted by schumacher
my crank is pressed?
Yep, but that's not the problem.
'02 was the last year of the Timken Lefty bearing which supported the hot forged crank so well. It's only available now through the S/E P&A book at rebuild time.
'03 they went to a cold forged crank ( still decent,) then '07 that weak cast crank ( not so much!)
Biggest problem was the 07 cast cranks that slipped too frequently.
Personally wouldn't own anything newer than '02. ( Currently workin' on my second 100,000 miles on my '00 S/E RG.)
