2012 SG ABS wheel bearing ?
04-19-2012, 07:47 PM
If I remember correctly the ABS bearings spacing is different than on the non ABS bearings? Anyone know if this is correct?
Thanks
04-20-2012, 01:00 AM
I understand the bearings are completely different and have a sensor magnet in them.
04-20-2012, 08:51 AM
I have done a little more checking and it appears that the ABS bearings are not as wide as the non ABS and a spacer can be used on the ABS bearings and your stock axle spacers can then be used.
04-20-2012, 09:08 AM
I'm running a set of ABS wheels on a non ABS bike, don't remember the spacer sizes, but it was a lot easier & cheaper to do, because I had the spacers already.
04-20-2012, 10:59 AM
ABS bearings are wider than the non abs bearings. ABS bikes do not have a spacer on the left side, but rather have the abs pickup.
blackscootersociety
Wheels/Tires
01-16-2017 06:09 PM
glock221
05-08-2014 11:32 PM
Faststeel
01-28-2013 03:25 PM
01heritage
07-31-2012 10:26 PM
bohica
11-04-2008 09:23 PM
