shifting problem
shifting problem
im 06 FXDBI is tough to shift into and out of 3rd. I'm not savy on gears but I just changed the fluid to see if that would solve anything. starting with the easiest solution first. The old fluid was low and very dirty. Don't remember the last time I've changed it. Must be years. anyway, before I changed the fluid it was hard to shift throughout the gears so changing it helped a little. wondering if I need to change the clutch pack or what. anyone have ideas? I'm about doing things myself if I can.
well the clutch cable doesnt seem to be the problem. the clutch is engaging. I adjusted it when I changed the fluid tho. and for there to be a problem in just 3rd seems to be weird. it's like I have to jam it into gear. Sometimes it'll go into N inbetween 4th and 5th gear too. the N light will illuminate too.
thinking nothing a little duct tape won't fix.
graphicdisaster
03-27-2017 08:31 AM
