MAP sensor code p0107 question?
Old 04-11-2012, 07:59 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Question MAP sensor code p0107 question?
OK so my 07 FXST started to cut out consistantly going down the freeway today and sometimes even dies at a light. Threw a code. Fuel filter only 10,000 miles on it. TPS is ok. Not sure if I should start throwing parts at it or not. If I do I'll get a crank sensor (no shavings on it), MAP sensor, and a fuel pressure regulator. Any thoughts! I have a PV to read the codes and check condition of TPS. 07 FXST 105,792 miles.
Old 04-11-2012, 09:04 PM
zoopman's Avatar
zoopman
zoopman is offline
If the bike is showing just the one code (po107) then replace the map sensor only and you should be good to go. My bike did the same thing about 3 years ago...I replaced the map sensor and all has been good since.
Old 04-11-2012, 09:07 PM
soft 02's Avatar
soft 02
soft 02 is offline
Thanks! Thats good to here. What were your symptoms?
Old 04-11-2012, 09:12 PM
zoopman's Avatar
zoopman
zoopman is offline
Exactly same as the ones you have described...cutting out and would sometimes die if I let go of the throttle. I was 45 miles away from home at the time but made it going about 45mph or so.
Old 04-11-2012, 09:14 PM
soft 02's Avatar
soft 02
soft 02 is offline
Way cool! Ordering part tonight! 43.00
Old 04-12-2012, 07:19 PM
soft 02's Avatar
soft 02
soft 02 is offline
double post
Old 04-18-2012, 10:58 PM
soft 02's Avatar
soft 02
soft 02 is offline
Ok replaced the cam sensor and MAP sensor and didnt fix it. Turns out got some advice on the forum that those sensors have a 5v signal voltage and a good ground is critical. Sure enough the ground was fuzzy and coroded. Didnt follow my rule about 90% of elec issues are a bad ground. Thanks agian!
Old 06-24-2012, 08:42 PM
Jim Martin's Avatar
Jim Martin
Jim Martin is offline
Stage I
Default Soft 02...Bad ground
I am having same problem with same code. Where do you check for the bad ground????
Old 06-24-2012, 09:31 PM
soft 02's Avatar
soft 02
soft 02 is offline
Take the seat off and right at the bottom of the tank bib. About 4-16gauge wires on one of the loom hold down bracket bolts.
James Hager
04-12-2018 05:38 PM
edgeofinsanity
03-25-2012 02:56 PM
rigglemg
12-16-2010 10:55 AM
Kraza
Exhaust System Topics
09-01-2006 02:51 PM
srigas
04-10-2006 04:52 PM
Quick Reply: MAP sensor code p0107 question?
