Spectro trans fluid?
Old 04-10-2012 | 01:16 AM
dfndr's Avatar
dfndr
Default Spectro trans fluid?
Anyone use Spectro V-twin Trans Fluid? Pro's? Con's? Thanks.
Old 04-10-2012 | 08:02 AM
oct1949's Avatar
oct1949
seen it but none of my buddies use it.
Most here go with Mobil 1, 75-90 GL..
Old 04-10-2012 | 10:18 AM
dyna rider's Avatar
dyna rider
Default Spectro
Yeah, I use it in my tranny. As long as the clutch is adjusted correctly, there is no clunk when shifting gears. Good stuff. SAE 75W140
Old 04-10-2012 | 01:33 PM
RK4ME's Avatar
RK4ME
I trust Spectro products.
Old 04-10-2012 | 01:48 PM
FUBAR55's Avatar
FUBAR55
Spectro Platinum 6 speed (ok for 5 speed too)
It's all I use. You'll notice a huge differance.
Old 04-10-2012 | 02:20 PM
BillM's Avatar
BillM
I use the same stuff as FUBAR. Big difference in how smooth the tranny shifts. It is still clunky butt then again most of the gears are straight cut in the tranny.
Old 04-10-2012 | 06:03 PM
QehQeh's Avatar
QehQeh
Changed my fluids last week in preparation for the River Run, the Spectro gear oil had 7k miles on it. After I drained it, I felt like putting it back in the trans. It looked, felt, and smelled like I had just poured it from the bottle. Very little debri (more like a drop of metalic paint) on the magnetic drain plug. I'm not saying it's better than anything else but, it's certainly as good as anything available.
Old 04-10-2012 | 06:06 PM
Shredding rubber's Avatar
Shredding rubber
It's as good as anything else out there. Better than using motor oil.
Old 04-11-2012 | 11:44 AM
RK4ME's Avatar
RK4ME
Please define "motor oil".
Old 04-11-2012 | 01:27 PM
jakenok's Avatar
jakenok
If you don't use HD products in your HD, it will self destruct and you'll get pimples...
