Newbie need help with throttle
04-07-2012 | 10:24 PM
Bike dies when giving throttle carb rebuilt because of stuck float also lots of slack in return cable idles perfect xl883 1988 cv carb
04-07-2012 | 11:33 PM
What was it doing before rebuild. Who did rebuild. Will they do it over. Have they ever rebuilt a harley carb before.
04-07-2012 | 11:52 PM
Your parts and service manuals will show you what you need to know. Otherwise you're just guessing, maybe guessing wrong.
04-08-2012 | 12:03 AM
Did you pull the intake off? if you did, you might have an unseated intake gasket. When you twist the wick, do you see raw fuel being sprayed into the throat of the carb? depending on how much or how little which is my guess, you have to adjust the linkage on your accelerator pump.
Did you re install your VOES via the main vacuum line to the back of your carb or intake?
more info my friend & we'll get ya back in the wind!
Hatch.
04-08-2012 | 02:22 PM
Does it pop when giving it gas? I had a sporty that did that after a jet change.
Turned out to be a leaky intake.
04-08-2012 | 03:26 PM
From: Back in the Good Ole USA. South Carolina to be exact.
Quote:
Originally Posted by
Vdoubleyou
Sounds like float level is too low now. Adjust float level. Adjust slack out of throttle cable.
izzyfutch
Ironhead
11-22-2017 04:23 PM
triple604
Engine Mechanical Topics
03-07-2017 05:52 PM
theundeadelvis
EVO
20
10-28-2013 08:32 AM
MBRADE
Carburetor Related
05-12-2013 08:47 AM
Pauly
Exhaust System Topics
06-08-2006 10:48 PM
