Clutch adjustment question
Old 03-28-2012 | 11:35 AM
Coloradohunter's Avatar
Coloradohunter
Default Clutch adjustment question
Last night, I took the bike to an empty parking lot to practice some of the Ride Like A Profriction zone techniques. After about 50 yards of "slow race", the clutch seemed to turn to mush. Had to pull it all the way it to get anything out of it all all.
After a few minutes of normal riding, it returned to normal operation.
Never had this issue on my RK and being a non wrenching, non mechanic kind of guy, I don't know WTF happened.
Thoughts, opinions, comments??
Old 03-28-2012 | 11:46 AM
oct1949's Avatar
oct1949
Not sure what U mean to get anything out of it at all..
Does that mean to get it to slip or it wouldn't release.??
Problem is we don't know how long has the oil been in there, how long since the clutch was adjusted, or even if the cables has been lubed..
find out the answers to above questions to see if just some regular maintenance would fix the problem.
U have to explain the problem a little better so we can at least understand whats going on.
Old 03-28-2012 | 11:55 AM
Coloradohunter
There was nothing but slack until the lever was almost pulled all the way in. Then there was no friction zone. It was either engaged or not. It's been a week and 400 miles since its 1000 mile break in service.
Old 03-28-2012 | 12:14 PM
TI06's Avatar
TI06
Sounds like your clutch cable is stretched, just need a cable adjustment. Every new bike I've had the clutch cable stretches out (clutch lever all the way to grip). Once you tighten the clutch cable things will be much better. I find it takes about 5,000 miles and then the clutch cable is done its excessive break in stretching.
Old 03-28-2012 | 12:49 PM
lbkr22's Avatar
lbkr22
I've got about 900 miles on my RK and have had to have the cable adjusted once already.
Old 03-28-2012 | 12:51 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Do a complete clutch adjustment with the bike dead cold. Won't hurt anything and you know it is done right.
Old 03-28-2012 | 01:18 PM
Nor Cal Mafia's Avatar
Nor Cal Mafia
I would slack all the way off the cable open the primary and adjust the nut then make your adjustments on the cable
Old 03-28-2012 | 04:07 PM
1broketramp's Avatar
1broketramp
If it returned to normal sounds like the clutch was hot.
jf7689
EVO
11
10-23-2017 04:13 AM
dandrumheller
06-16-2016 09:39 AM
FFHD05
08-28-2011 06:09 PM
mi2az
08-01-2011 06:03 PM
ajay450
12-28-2010 04:33 PM
Quick Reply: Clutch adjustment question
