What the question says....can the fairing cig lighter plug be used to power a gamin gps which typically would plug into a car outlet? Harley says no in literature....I'm guessing liability reasons. I have a ram mount for a gps and would like to just occasionally cig plug it.......thanks!
i don't think i'm sticking anything in my cig lighter on my fairing, put my iphone up to it, next day none of my gauges work. blew a fuse or something. it worked for the time but i dunno what happened.
Just run a wire to your battery with inline fuse and you don't have to worry about fugging anything up. I run my cig lighter on my dyna strait off the battery with inline fuse off the battery tender plug.
I use mine to run my GPS. Had to switch the wires on the lighter first. Have to make sure the hot wire is on the center and the ground is on the outside of the plug first. Mine works like a champ after that.
No reason not to. A cig lighter draws far more current than any electronics you'll plug into it. H-D probably says no because they'd prefer that you purchase and install an accessory socket.
I ran my power wire for the GPS down the handlebars and thru the hole in the fairing that the clutch cable runs thru. I hard wired it into the power wire for the lighter with terminals that I had here from other electronics and have had no problems since.
