Syn3 cost
Old 03-22-2012, 09:50 PM
2011HDFATBOYLO?'s Avatar
2011HDFATBOYLO?
2011HDFATBOYLO? is offline
Originally Posted by Shredding rubber
Not really.Group 3 syn is oil that has hydrogen bubbled through it to remove impurities. Examples of group 3 oils can be found as castrol syntec,all mobil 1 products other than the extended performance line and the advanced fuel economy line. Group 4 and 5 syns oil is derived from The crude and is broken down to it's more basic elements then put back together without any impurities or unnecessary compounds.
Brands such as red line are group 5,amsoils offerrings are group 4 except tge oem line and the XL line.
Real group 4 and 5 oils are super expensive. Expect to pay at least 10-15 dollars a quart. Group 3 is much cheaper to produce and can be found for under 10 bucks a quart.
I hope I helped clear it up a bit.
In north American the term synthetic doesn't really have anything to do with the oil,its a marketing term. In Europe a labelled syn has to be minimum group 4. That's why you will see oils with "synthetic technology" and similar marketing crap on some bottles.
If you see bottles market "European car formula" they are and have to be minimum group 4 base as well
Thank you, that makes sense then.
Old 03-22-2012, 09:51 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
Originally Posted by louisianaSVT2001
Can't find 20 50 Mobil1 locally, I live in the backwoods of Louisiana. I run mobil1 in both of my trucks.
I just thought it was outrageous to jump up in price that much.
If you can find the 15w-50 version you can use it instead. Harleys can use any oil with the second number being 50. That is the grade at operating temp. So in reality you can use a 5w-50 in the engines,they will shear a bit faster than a 15w-50 or a 20w-50 but won't shear as fast as a mineral oil.
Our bikes don't have a shared sump so shear isn't really as big an issue for us as it is for the imports. The tranny turns the oil into water from the gears beating the hell out of it.
Old 03-22-2012, 10:15 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Well I sent someone to pick up oil today at dealer. WOW, 13.95/quart.....I think last time I bought syn3 it was 9.95/quart. This is stupid
I will now only order from JP or Dennis Kirk and thinking of going amsoil
Ok done venting
Advanced Auto just had Mobil1Vtwin 20w50 for $7.99 and Valvoline Dino 20w50 MC oil for $5.99. You have to watch for the sales and stock up.
Scudda
Oil Archive (no new posts)
53
04-09-2021 01:58 PM
01fxd89
07-06-2012 02:52 PM
bikehe
11-28-2010 06:55 PM
DADAWG
03-01-2008 01:31 PM
98rdking
01-31-2007 12:43 PM
Quick Reply: Syn3 cost
