Stator screws backed out and destroyed primary 06 dyna
Old 03-21-2012 | 06:18 PM
Bluetoys's Avatar
Bluetoys
They know about it. The stator was BOLTED to the compensator and the bolts loosen and destroy the windings. The newer ones are welded, NEVER allow them to try to use the bolted ones, IMHO.
Old 03-21-2012 | 06:26 PM
Bluetoys's Avatar
Bluetoys
Also, and you are not gonna like hearing this, you should have the primary drive sprocket removed and the main shaft bearing checked. It has a plastic bearing carrier and it can fail and cause the mainshaft to wobble and the seal will leak tranny fluid. Everything they do to repair the stator problem will be redone to get to the bad bearing, if it goes, or is in the process. While the sprocket is off, installing a 30 tooth sprocket is as easy as ordering one, the perceived power increase is worth the cost of the sprocket, for sure.
Old 03-21-2012 | 08:49 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by slimpickins
OC Harley tells me it's going to cost $2100. Moco CS says its not a known issue and they will not do anything about it. I don't know what to do. I need help.
Stator self destruct 06/07 Dynas
https://www.hdforums.com/forum/dyna-...-07-dynas.html
How many 06 dyna owners had failed Alt/stator/pulle y assy
https://www.hdforums.com/forum/dyna-...le-y-assy.html
Looks like it's my turn for a Roter & Stator
https://www.hdforums.com/forum/dyna-...nd-stator.html
06 dyna Primary noise--- stator
https://www.hdforums.com/forum/dyna-...se-stator.html
Stator Rotor 2006 Dyna's
https://www.hdforums.com/forum/dyna-...006-dynas.html
06 dyna stator/rotor
https://www.hdforums.com/forum/dyna-...tor-rotor.html
A Few Questions - Stator and Indy Shop
https://www.hdforums.com/forum/dyna-...indy-shop.html
06 stator-rotor findings
https://www.hdforums.com/forum/dyna-...-findings.html
Old 03-22-2012 | 01:25 AM
Scouser1's Avatar
Scouser1
Thanks to this forum , when I was looking at getting my 06 Dyna I read loads of posts regarding the inner primary bearing and stator so when I bought mine I got the inner primary done under warranty and got them to put a later stator in at the same time.
Hopefully thats it all done now to ride
Scouser
Old 03-22-2012 | 07:12 AM
Rusty Needles's Avatar
Rusty Needles
Yep, getting new stuff. New stator, clutch pack, primary chain, ipb and sprocket. That's just off the top of my head. Bike should be done on sat. After I get it back I'll look into my options.
Old 03-22-2012 | 10:42 AM
matthew175's Avatar
matthew175
6th Gear
Default me 2
Stator just gernaded in my 06 superglide, original owner no extended already had IPB done 2 years ago thru Moco. Did u get moco cover parts too? Got 53K kms Thanks
Old 03-22-2012 | 10:43 AM
matthew175's Avatar
matthew175
6th Gear
Unhappy me 2
Old 03-22-2012 | 11:03 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Better tell them if your trans and inner primary case do not have alignment dowels you want the cases replaced. HD Milwaukee customer service knows all about this. They replaced my cases n/c.
Old 03-22-2012 | 11:04 AM
KBFXDLI's Avatar
KBFXDLI
Originally Posted by matthew175
The rotor stator kit is only about $230. Go to your dealer and complain. This is a known issue with all 2006 dynas.
Old 03-23-2012 | 07:10 AM
Rusty Needles
I had the cases changed out a couple of years ago when the ipb took a dump. I wonder if I'm the only guy that's getting stuck with paying for parts because of this stator disintegrating in my primary and taking everything else in the with it?
Quick Reply: Stator screws backed out and destroyed primary 06 dyna
