Ever try to push start your bike?
Old 03-15-2012, 11:39 AM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
These battle wagons today unless you've 11 volt or better in the battery it ain't happening , and I don't think it's even possible with EFI bikes ? Correct me if I'm wrong on that one please , haven't heard of it being done .
On the newer FI bikes you have to have enough juice to turn on the fuel pump and fire up the electronics. Without it (dead battery) it just ain't happening!
Old 03-15-2012, 11:56 AM
brenn's Avatar
brenn
brenn is offline
Originally Posted by SeniorChief56
Left my lights on,tried to start but no luck. Was on a good hill , rolled bike down hill and tried to pop the clutch in 1st, 2nd and 3rd. Nothing came close to turning over the engine. All I did was skid the back tire. Is there a way to push the bike and pop the clutch and have it start? I have done this before on my other "non-Harley" bikes and they all started. WTF over?
Is your Harley fuel injected, as opposed to carb "non-Harley" bikes?
If it's carbed then it should be easy to push start. I was taught to do it in 2nd - just remember to turn on the fuel, power and run switch.
Old 03-15-2012, 12:38 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 15,160 Likes on 6,705 Posts
I did it when I stopped to help a guy with an '09 Electra-Glide. He had a bad starter clutch and it wouldn't engage, but had enough juice for EFI. He pushed me about 3-4 times before it dawned on me that the key fob should probably be in my pocket instead of his (closer to the bike). I got it to fire right up after that.
Old 03-15-2012, 12:54 PM
editbrain's Avatar
editbrain
editbrain is offline
We pushed started a Nightrod at BBB last year. The guy had left his lights on.
Old 03-15-2012, 01:02 PM
XKnight's Avatar
XKnight
XKnight is offline
I've push-started my old Sporty a few times, but that was back in the days of carburetors. Haven't tried it with my Road King.
Old 03-15-2012, 01:08 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
Originally Posted by NDBadlands4-2
I have push started a old Yamaha of mine, but I was always told the EFI bikes require power. The fuel pump needs to be up and running and the injectors etc need power to run. If the starter was bad, and the battery good I guess it would be possible, but with the battery flat....... No go.
Pretty accurate. The pump has to get enough pressure in the fuel lines to spray.
The cam position sensor also needs some power to tell the ignition to fire.
Boost the bike off your car or charge the battery with a charger.
Old 03-15-2012, 01:13 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Yes. Pushed mine twice. No you cant put a kicker on it because the crank sensor needs more rpm than a kicker can give.
Old 03-15-2012, 01:31 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,988 Likes on 17,898 Posts
Originally Posted by piasspj
I believe the voltage can be less than that, probably could work down to about 8V maybe a little less. Chances are better if the fuel line still held some pressure.
Read someplace it was around 10.something or just under 11 but that was before EFI , with fuel pump involved now anything lower I donno .
Old 03-15-2012, 01:50 PM
TwiZted Biker
Originally Posted by zukeeper
I could be wrong , I dont ride a twinkie , but I have been told by more than one person that the new bikes cannot be kick started because there is a certain rpm the engine has to hit before it will be alolwed to fire. something to check out before dropping money on a kicker
Can't say for twinkies but EVO's had to make 2 full revolutions before they would fire with factory ignition systems , any kicker conversion I've done we always changed the stock out for Dyna or similar aftermarket system .
Old 03-15-2012, 02:49 PM
trhayes76's Avatar
trhayes76
trhayes76 is offline
Push started mine twice...it works
Quick Reply: Ever try to push start your bike?
