Boot Suggestions
#53
Danner Ft Lewis - gore tex liner, insulated or not, very comfy once broke in, first pair I have over 15 years and still would be wearing them (with new soles) had one not gone missing at work. Got a new pair to break in now and a lower cut version called the Blackhawk.
#54
#55
Looks like a similar boot, the only things I don't care for is the white stitching and the full heal rather than the sloped heal but that is just personal preference. When I got the new Ft Lewis boots I went with the 200g insulation and my experience with them so far is that while the insulation helps, when temps get around 40 or lower then even with wool socks your feet WILL get cold after a while. I also notice that in spite of the full gore-tex bootie you can still feel some drafts at lower temps. (or maybe just getting cold) And yet, with some Gerbing sock liners I find myself reaching for the shorter Blackhawks even when temps are just above freezing so if you want warm feet - plug in!
#56
#57
Thanks for your impressions. I would consider the Fort Lewis, but Danner's web site claims they are built narrow for better support when on your feet and I have wide toes. I am planning to add Gerbing boot inserts, but I wanted to start with a boot that could do a good job of keeping the wind out in the first place. Do you put anything like snow-seal on your boots? I'm wondering if that might help prevent wind from penetrating the seams?
I'm not entirely sure there is any air leaking in, might just be an impression from getting cold after a period of time since they all have a full gore-tex bootie which in theory should not allow wind or water to penetrate. There's no need to snow seal them, in the past I have stood in ice cold (mountain runoff) streams up to the top of the boot and not felts one drop of water.......unless it goes over the top - then you're screwed.
AmericanMuscle
11-18-2012 09:58 AM
