Throttle sticking
Old 02-22-2012, 08:18 PM
TCC2's Avatar
TCC2
TCC2 is offline
2nd Gear
Default Throttle sticking
Went for a ride today and found that my throttle is sticking. Does anyone have any suggestions on how to fix this issue?
Old 02-22-2012, 08:22 PM
vheflin's Avatar
vheflin
vheflin is offline
Is it the throttle plate sticking or the cables binding?
Lube the throttle and idle cables and recheck.
Old 02-22-2012, 08:24 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
First check how tight the throttle lock is. If it's tight loosen it. If it's not that then the cables may need lubricating. If it's not that the cable might be bound up against something. If it's not that the carb might need help. If it's not that you might need a new bike.
Old 02-22-2012, 08:35 PM
piasspj's Avatar
piasspj
piasspj is offline
What model and year of bike? Does it turn freely or does it just not return to idle when you remove your hand? When was the last time you checked and lubed the cables? Did you recently change grips?
Old 02-22-2012, 09:49 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Mine started doing that after I let it sit for about a month following a long wet trip to Alaska. Talking to an HD tech and he said it is probably rust in the cables and to just lube them and the rust or grit would work loose and flush out. I have lubed the cables three times using a lot of lube and they are better but not right yet.
A good suggestion short of replacing the cables would be welcome.
Old 02-22-2012, 10:02 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
If you lubed the cables and it didnt fix it then I would dis connect the cable at both ends and tie a sandwich bag around the cable ends at the carb and lube them plus work them in and out until the wd40 or whatever comes out at the carb/throttle body end. This should flush the gum/rust out of the cable compleetly. Good luck!
Old 02-22-2012, 10:19 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
Just a question, what makes everyone think he has a carb? My EFI has a throttle cable.
I understand the principle but ya know what I mean. The suggestions are spot on.
Would be nice if the OP provided more information the entire situation.
Old 02-22-2012, 10:42 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
It's funny that guys come here with questions about there bike but fail to tell us what year and model they have !!!
Old 02-22-2012, 10:59 PM
nitrohound's Avatar
nitrohound
nitrohound is offline
Mine was sticking. Cruise control lights were coming on also, when I first bought it used. Housing was clamped down too tight on throttle by wire. (or misaligned). Put back, no problems,
hound
Old 02-23-2012, 01:04 AM
Dr. Tiki's Avatar
Dr. Tiki
Dr. Tiki is offline
The OP joined in 2012 and has 2 posts and asks about his throttle being stuck. I am going out on the limb and guessing it's a 2011 or 2012 bike. As Nitrohound suggested, check your housings.
Quick Reply: Throttle sticking
